Goodmorning guys,
i'm trying to define the dimensions of a desalter, given a specific flowrate.
In details, i have two desalter in series (1st and 2nd stage desalters)
I would like to define the overall dimensions of the vessel, not the exact ones, before asking the desalter supplier. I also know that the dimensions will depend on other characteristic like desalting efficiency, quantity of salt in the crude oil etc....Here i would like to understand only what is a typical value for the residence time in a desalter vessel.
These are my data:
FLowrate:
45000 BPD
V=312 m^3 (volume flowrate)
G=250000 kg/h (mass flowrate)
density=800 kg/m3
design pressure=10.2barg
design temperature=93°C
operating pressure=8.5/7 barg (1st stage-2nd stage)
operating temperature=65°C
salinity in water formation=200000 mg/l
outlet allowable salt content in oil=81 PTB
In order to define the overall dimensions of the vessel i have to know the residence time.
Referring to a horizontal separator a typical residence time could be from 5 to 15 min, is this valid also for the desalter or i have to choose something else?
In the datasheet there is in my hand (not calculated by me), the given dimensions are 3600mm*12300mm.
The formula used to define the vessel diameter and lenght is the following (given from horizontal separators design).
t=residence time
holdup volume=V.hold=t*V
R=L/D=2.5
Diameter=D=cubic root [(V.hold*4)/(3.14*R)]
Lenght=L=2.5*D
Whit this formula and a residence time of 15 min, it gives me 3400mmx8500mm, quite distant from 3600mmx12300 given in the datasheet.
Should i have to change the residence time or the L/D ratio in order to obtain the dimensions given in the datasheet?Is there any other thing to be considered?
In example, if i put R=3 and t=25 min, the dimensions are 11500mmx3800mm, similar to the datasheet.
Is it correct to use that kind of formula to obtain the dimension of the vessel or should i use the settling velocity of the dispersed phase in the continuous one?
I would like to point out that this is only a preliminary design of the vessel, the final one will be done by the supplier of the desalter.
thanks
Matteo
Residence Time For A Desalter
Started by Matteo Giorgio Marrano, Jan 21 2009 05:53 AM
No replies to this topic
Posted 21 January 2009 - 05:53 AM
Steam Flow And Heating Time In Batch ReactorStarted by Guest_seagal6_* , 16 Jul 2025 |
What Can I Do With My Leftover Time In UniversityStarted by Guest_Acetimeter_* , 25 Jun 2025 |
Psv Release Rate Vs TimeStarted by Guest_stu_* , 30 Nov 2024 |
Time Required To Heat Up A Fluid In A VesselStarted by Guest_panoska_* , 24 Jan 2023 |
