Heat Exchanger Tubes - Minimum Thickness
#1 Bill B
Bill B
  • 56 posts
Posted 10 February 2009 - 08:34 AM
I am designing a heat exchanger and needing to estimate the minimum tube thickness (A-213 tubes, 304L). Using the Barlow equation, at 1200 psi / 450°F design, and an allowable stress of 13,200 psi, I have estimated the min thickness to be .033", plus any allowance for erosion.
Is there a rule of thumb I should use? We are processing syn gas through the tubes, CW on shell.
#2 djack77494
djack77494
  • 1,282 posts
Posted 10 February 2009 - 09:58 AM
Normal practice is to have NO erosion/corrosion allowance on heat exchanger tubes. This would be even more true for stainless steel tubes.
#3 Bill B
Bill B
  • 56 posts
Posted 11 February 2009 - 06:12 AM
QUOTE (djack77494 @ Feb 10 2009, 09:58 AM) <{POST_SNAPBACK}>
Thanks for the input. I will proceed with no allowance. I will try to come up with vibration analysis equations and check my "minimum" tube thickness vs. that number. Bill
#4 kuldeepd
kuldeepd
  • 19 posts
Posted 31 March 2009 - 03:49 AM
http://www.processca..._Exchanger.aspx
hope this helps.
regards
KD
