For an air cooler (induced draft or forced draft) can any one tell me what percentage of natural cooling can be considered. In other words when the fan power goes off how much cooling can be considered.
Natural Cooling In Air Coolers
Started by ayan_dg, Mar 18 2009 10:59 PM
Posted 18 March 2009 - 10:59 PM
Posted 19 March 2009 - 03:50 AM
QUOTE (ayan_dg @ Mar 18 2009, 10:59 PM) <{POST_SNAPBACK}>
Around 20 percent of Rated Capacity.
Posted 19 March 2009 - 03:52 AM
QUOTE (ayan_dg @ Mar 18 2009, 11:59 PM) <{POST_SNAPBACK}>
I don't think your question is very relevant. An air cooler is designed for a specific duty considering ambient air temperature for the location where the air cooler is located. I am very sure that if the fan stops due to power failure, you will not be able to maintain your temperature at the cooler outlet and hence the percentage cooling question doesn't make much sense. Power failure also means that the other equipment connected to the air cooler will also stop functioning and the situation leads to an emergency shutdown of the unit/plant due to power failure. For critical services, which may or may not include an air cooler, to avoid such a situation a UPS system is provided which ensures that all critical equipment requiring electric power do not face such a situation. Hence I don't see the point of your question in a real life industry situation.
For mechanical reasons, i.e. maintenance of the fan many operating companies specify two fans (1W + 1S) per bay of the air cooler, so that if one fan is under mechanical maintenance, the other fan can fulfill the duty requirements of the cooler.
If this is simply an academic exercise, then I think you probably need to talk to some air cooler vendors to get an answer.
Posted 19 March 2009 - 05:33 AM
Ankur,
The information is relevent when you want to give DT (design temprature) of upstream piping and downstream piping for an air cooler. Also in calculating relieving load and condition for relief downstream of the air cooler . for a bigger air cooler this is very relevent.
Please note to paragraph 5.6.4 Air-cooler fan failure of API 521.
I think ayan_dg is questioning to take credit for partial condensing capacity due to natural convection in the case of fan failure.Based on this he/she can determine relevant relief rate.
![]() Guidance On Sizing Jacketed Pipe For Glycerine CoolingStarted by Guest_Kentucky08_* , 28 Jun 2025 |
![]() Hello, Design Of Natural Gas Liquefaction Processes.Started by Guest_guoyinyanliner_* , 18 Jun 2025 |
![]() What Kind Of Cooling System Should I Use To Cool Down A Jacketed MixinStarted by Guest_HollyBoni_* , 31 Jan 2025 |
![]() Pressure Loss In Piping - Cooling Tower-Shelltube HeatexchangerStarted by Guest_Alneto_* , 29 May 2024 |
![]() Maximum Natural Gas Flow Through OrificeStarted by Guest_ukrche_* , 10 May 2024 |
