i just wanted to ask about the specifications, industrially, a designed flash drum.. because i had design design a flash drum.. here are the info of my design.
a) vertical flash drum, vap frac = 0.3, volume flow = 514 m3/hr, with P = 145 barg, T = 250 C. and the L = 16.9 m and D = 2.89 m and thickness = 24 cm
horizontal flash drum, vap frac = 0.1, vol flow = 455941 m3/hr, with P =0.15 kpa, T = 18 C, L = 35 m and D = 10 m.
the questions..
a) is my design are industrially valid.. bcos it seems that the L are look really big..
what are the specifications and rule or limit to a flash design.
