hello,
Does anyone know which materials are best to use for the construction of distillation columns for the production of tetrahydrothiophene?
Also in regards to storage of tetrahydrothiophene, what materials are most appropriate to be used so that any corrosive affects would be to its minimum?
THANKS!
Distillation Column Material Selection
Started by justine04, Mar 30 2009 01:55 AM
Posted 30 March 2009 - 01:55 AM
Posted 30 March 2009 - 02:50 AM
QUOTE (justine04 @ Mar 30 2009, 07:55 AM) <{POST_SNAPBACK}>
hello,
THANKS!
THANKS!
For this distillation query more information is required: What else is in the column and to what concentrations? The temperature and pressure is also required? Also do you require advice requiring plate and packing?
For the storage the compound is not corrosive and would be stored at room temperature feasibly. SS should be fine 304/316. I would like to see if carbon steel is good as well but I do not have more information on this compound so that is as far as I can go.
Posted 30 March 2009 - 03:37 AM
I have attached the process of production.
Could you please also tell me what would be the appropriate type of storage for tetrahydrothiophene? Is a normal stainless steel tank good enough in this case or are cylinders better?
Because there'd still be traces of caustic soda and H2S entering the distillation column, what do you think should be the material? I've considered Nickel 200 and maybe also SS317. Not really sure if there are others that I should think about.
Thanks so much for helping
Selection Type Of Heater For Refrigerated PropaneStarted by Guest_livetolove003_* , 07 May 2025 |
![]() Material Balance With ReactionStarted by Guest_Kentucky08_* , 30 Apr 2025 |
![]() Methanol Water Distillation ColumnStarted by Guest_Kakashi-01_* , 27 Jan 2025 |
