Flarenet- Simulating Water Seal
#1 rxnarang
rxnarang
  • 133 posts
Posted 13 April 2009 - 01:41 AM
This is regarding Flarenet:
I am simulating a flare system where I have the flare tip pressure drop curve whiih enables me to have a variable pressure drop across the tip. However, the flare stack base has a water seal drum which will give a constant pressure drop irrespective of flow rate. How does one simulate the water seal's constant pressure drop, while keeping the variable pressure drop in the flare tip?
Thanks for your help
#2 JoeWong
JoeWong
  • 1,223 posts
Posted 06 May 2009 - 12:06 AM
This may be too late... You may consider Flow Bleed component in FLARENET...
#3 Traileum
Traileum
  • 11 posts
Posted 27 October 2009 - 11:51 AM
How are flare tip pressure drop curves generated? Any body out there knows?
#4 JoeWong
JoeWong
  • 1,223 posts
Posted 03 December 2009 - 08:51 AM
Normally flare tip vendor will advise you the pressure drop for their proprietary tip.
For ordinary pipe flare tip, you can use flaresim to estimate pressure drop or you may "Quick Estimate Flare Tip Pressure Drop"
