what is the upper tempertaure limit for acceptable opertaion of liquid film seals in centrifugal compressors?
what determines this---the material ofthe mating faces? the machine rpm? the kind of oil used for sealing mineral or synthetic?
thank you
Centrifugal Compressor Oil-film Seals
Started by , Apr 18 2009 12:00 PM
No replies to this topic
Posted 18 April 2009 - 12:00 PM
Compressor Selection Based On Flowrate & Compression RatioStarted by Guest_Dhams_* , 19 Jan 2026 |
The Centrifugal PumpStarted by Guest_guoyinyanliner_* , 15 Dec 2025 |
Purge Gas For Centrifugal CompressorStarted by Guest_Lyne_* , 19 Oct 2025 |
