Hi all,
I would like to know the differences between actuated valves and control valves.
Also, I would like to know what are:-
1. self operated pressure reducing regulator
2. self operated backpressure regulator
Also, please tell me where can I get fundamental / basics of all types of valves.
Thanks very much for your help.
regards,
shinloo
The Differences Between Actuated Valves And Control Valves
Started by shinloo, May 26 2009 11:13 PM
Posted 26 May 2009 - 11:13 PM
Posted 28 May 2009 - 04:36 PM
shinloo,
I would recommend you get your hands on the Emerson (formerly Fisher) Control Valve Handbook for thorough orientation to all control valve topics. Regulators, by the way, are really a type of control valve not requiring a separate controller.
In a sense, most valves are actuated - you can in some manner adjust the valve's opening at will. More common usage of the term, however, would be to use the word "actuated" to mean a valve which has a device (actuator) attached that can supply the mechanical force needed to cause changes in the valve's position; e.g. from open to closed. That device may be a motor, diaphragm, or piston, so the motive force may be electrical, pneumatic, or hydraulic. A control valve is just an actuated valve where the actuator is modulated via a signal from a controller.
A self operated regulator has a connection to the process and uses a process variable such as pressure, level, or temperature to generate the force that actuates the valve. Perhaps the simplest example of a self operated regulator is the level regulator valve inside a toilet. The liquid level causes a float to rise or sink and the float, through mechanical linkages, adjusts the valve's position.
You contrast the terms "pressure reducing" and "backpressure" regarding regulators. the difference is merely what variable is being controlled. The pressure reducing regulator is controlling (reducing) the upstream pressure; the backpressure regulator is controlling the downstream pressure.
Posted 28 May 2009 - 09:50 PM
QUOTE (shinloo @ May 27 2009, 09:13 AM) <{POST_SNAPBACK}>
Hi all,
regards,
shinloo
regards,
shinloo
Dear shinloo Hello /Good Morning,
Although you have been very thoroughly guided by Doug &Joe already, but somehow
I have a query as if the question in your OP was to deal with 'Controlled values' and 'Actuated values' or rephrasing 'Controlled variables' and Actuated Variables' if this is any way the case then scenario might change for responding to your OP.
Posted 01 June 2009 - 02:43 AM
Hi all,
Qalander, thanks for your concern but my question is well-answered by Joe and Doug. Thanks, everyone for your replies.
SL
SL
Equal Load Sharing And Anti-Surge ControlStarted by Guest_panoska_* , 02 Nov 2025 |
Control Strategy For 2 Air Compressors In ParallelStarted by Guest_panoska_* , 31 Oct 2025 |
Real Or Ideal Cp/cv For Control Valve CalculationsStarted by Guest_sumwunrandom_* , 14 Oct 2025 |
Sizing And And Process Control Of Filter PressStarted by Guest_Amalina Jamil_* , 11 Mar 2019 |
Igv Control For CompressorStarted by Guest_Lyne_* , 30 Aug 2025 |
