Wilson K-value Methods
Started by Guest_Chemical Toli_*, May 27 2009 03:55 AM
9 replies to this topic
Posted 27 May 2009 - 03:55 AM
Please, I need some data about Wilson K-Value methods, I'm using Chemcad 6.01.
If it is possible to post me the equation for this method or can anyone tell me how to find it on internet.
Posted 27 May 2009 - 07:01 AM
Have you ever heard of Google? Here's a link to the first "hit".
http://www.cocosimul...EA/activity.htm
Posted 28 May 2009 - 04:24 AM
Thank you very much Latexman I really appreciate your help but if it is possible to post me more about Wilson method I mean dhe equation of state by Wilson. I need for my thesis so I have to write about this medhod. The topic is "Simulation of distillation coulmn" and the sources that I've been consulting are on attachment.
Once again, thank you for your help.
best regards
best regards
Posted 28 May 2009 - 07:03 AM
Are you talking about the Becker-Kistiakowsky-Wilson equation of state? Again, google it. I got 110 hits when I googled "Becker-Kistiakowsky-Wilson equation of state". When I looked at your attachment it seems to me you want the Wilson equation for vapor-liquid equilibrium, not an equation of state. Are you sure what you are looking for?
Posted 30 May 2009 - 04:37 AM
Yes that’s it Latexman I want the Wilson equation for vapor-liquid equilibrium. If it is possible to post me more about this method, as I said I need for my thesis I have to write a one page report. Once again, thank you very much for your help.
Best regards,
Best regards,
Posted 31 May 2009 - 12:19 AM
Chemtoli ,
Perry Chemical engineers' handbook should support your querry .
Posted 01 June 2009 - 07:52 AM
Can you please post me a link. Thnank you
Posted 01 June 2009 - 08:28 AM
Are you looking to understand how to use the Wilson equation to obtain VLE data, or are you simply after interaction parameters? Which "Wilson" equation are you using? The one I'm most familiar with is Wilson's expression for excess Gibb's free energy that is usually used when modeling VLE with activity coefficients.
If you are looking for instruction on how the Wilson activity coefficient equation is used, you can try just about any thermo text. The ones I'm familiar with are Molecular Thermodynamics of Fluid Phase Equilibria by Prausnitz. Prausnitz also is co-author of The Properties of Liquids and Gases which has a section on VLE calculations. There's also Phase Equilibria in Chemical Engineering by Stanley Walas.
If you are looking for interaction parameters, I would start with DeChema Chemistry Data Series compilation of VLE data.
Posted 02 June 2009 - 07:32 AM
Thank you very much dear MrShorty
Dear MrShorty I just need to know what does mean Wilson method according ty my simulation example and to understand how to use the Wilson equation to obtain VLE data. Please can you post me links for books that you mentioned above. Once again thank you very much I appreciate your help
#10
Posted 02 June 2009 - 08:16 AM
I'm not sure what kind of link you are looking for. Maybe try books.google.com and enter the title as your search term.
How To Use 2 Different Property Methods In The Same Aspen Plus SimulatStarted by Guest_MattLochner_* , 23 Sep 2024 |
521 Fire Alternate MethodsStarted by Guest_therossboss_* , 19 Apr 2022 |
Definition Of Critical Electrical Loads And Methods To Handle ThemStarted by Guest_Vegeta_* , 14 Aug 2022 |
Friction Drop MethodsStarted by Guest_Unnatiyr_* , 24 May 2022 |
Multiple Base Methods For Stream In Aspen PlusStarted by Guest_Icehot1_* , 12 Feb 2021 |
