Then
What is the difference between Saturated air,Saturated liquid ,Saturated vapour?
What Is Saturation?
Started by ktrone, Jun 02 2009 11:38 AM
Posted 02 June 2009 - 11:38 AM
Guest_ellajid_*
Posted 02 June 2009 - 12:17 PM
As far as i know,
Saturated air: Is air that's had it's fill of water vapour. Meaning that any increase in the amount of water vapour in saturated air leads to the formation of dew.
Saturated Liquid: Is a liquid that has had it's fill of a solute in a solute/solvent mixture. Any addtion of solute will lead to it precipitating in the vessel containing the mixture.
Saturated Vapour: Is a term used to describe vapour that has been heated to the extent that it loses any moisture content. Any addtional heating will make the vapour cross into the super heated region in a T-S diagram. Any cooling of saturated vapour will lead to the formation of moisture in the liquid (wet vapour region in a T-S Diagram).
Posted 03 June 2009 - 03:45 PM
I like the definitions submitted by ellajid. To reword, saturated xxx refers to a condition where xxx is the predominant phase or substance but which is right at the point where a change in temperature or pressure will result in the appearance of a second phase. You won't find that definition in a dictionary, but it makes sense to me.
Langelier Saturation Index Validity For SeawaterStarted by Guest_Vegeta_* , 20 Jun 2022 |
Water Saturation Vs Water CutStarted by Guest_rs20170808@gmail.com_* , 13 Apr 2020 |
Calculate Refrigerant Saturation ValuesStarted by Guest_Pavan4b4_* , 30 Jun 2017 |
![]() Aspen Plus Saturation DataStarted by Guest_speakas_* , 22 May 2017 |
Is There Any Relation Between The Crude Oil Gas Saturation And EfficieStarted by Guest_latasabu_* , 06 Jan 2015 |
