hi there,
hope someone can help me.
1. How to calculate the maximum suction pressure by data given as follows:
atmospheric pressure - 98kpa
resistance suction valva - 2kpa
pipe resistance - 8kpa
2. What is permissible wear ring clearance in impeller with diameter of 150mm in a two stage pump at operating temperature 225 degree C
Please help me. Thanks in advance
Maximum Suction Pressure
Started by zaifull, Jun 05 2009 11:12 PM
Posted 05 June 2009 - 11:12 PM
Posted 05 June 2009 - 11:47 PM
Vapor pressure at pumping temp is crucial.
NPSHA = Vessel pressure+head-VP at PT - friction loss.
Compare this with the NPSHR state in the pump spec.
Presuming this is a small pump running at 3000/3600 rpm, a margin of at least 1m is required.
For high speed pumps, the margin evealuated as a ratio. Dont want to confuse you.
Again, refer to Heinz Bloch's book in Google books.
WR clearance of 0.5mm should be good for 150mm. Refer API610 on min running clearance.
Posted 05 June 2009 - 11:51 PM
thank you sir, it's helping me a lot
