Control Valve In Aspen Plus
Started by cmp74, Jul 08 2009 07:30 PM
Posted 08 July 2009 - 07:30 PM
I have a control valve which i need to include in overall hydraulic simulation of a flow process.
The datasheet has Cv and % opening for 3 different flow values (min.max.normal).
Also one data set is available for rating capacity, which includes Cv,Xt(pressure drop ratio factor) and Fi (pressure recovery factor).
Now , waht AspenPlus require is 4 sets of complete data for Cv, %Opening ,Xt and Fi.
My questions are,
1) is the dataset at rated capacity means at 100% opening??in other words, is the valve rated at 100% opening?
2) How do I get values of Xt and Fi at min-max and normal flowrates?or do they remain constant??
the valve is globe type with equal percentage characteristic.
thanks in advance
Posted 25 July 2009 - 01:19 AM
QUOTE (cmp74 @ Jul 8 2009, 08:30 PM) <{POST_SNAPBACK}>
My questions are,
thanks in advance
My questions are,
thanks in advance
1)The CV calculated for min normal max flow is for 100 % opening.But main thing is Cv selected which tells you the capacity obtained from valve
2)Xt and FL depends on vendor selected and valve type .You can get from vendor ...
3)In general for globe valve with equal percentage you can take Xt as 0.6
How To Model The Bitumen In Aspen Plus?Started by Guest_engrbab01_* , 28 Jul 2025 |
Automatic Choke ValveStarted by Guest_Mudassssir011_* , 22 Jul 2025 |
Parallel Control Valves Downstream Relief ScenarioStarted by Guest_pklavinsJ_* , 18 Jun 2025 |
