We have a duty of removing water which is almost 80%(w/w) in lactic acid (product) solution. The solution flow rates involved are 1000 kg/hr. The product is temperature sensitive and the water evaporation needs to be carried out under high vacuum. What is the best method one can recommend for such service? At higher concentrations the product is prone to foul the heat transfer surfaces.
It is intended to try something different from spray drying or thin film evaporator type equipment.
Thanks in advance for your inputs.
Lactic Acid Purification
Started by Rajesh India, Jul 16 2009 06:17 AM
No replies to this topic
Posted 16 July 2009 - 06:17 AM
![]() Equilibrium Data For Nitric Acid And WaterStarted by Guest_ksagarzazu_* , 07 Oct 2024 |
![]() Acid Base ExtractionsStarted by Guest_paradoxlost_* , 07 Jul 2024 |
Sulphuric Acid H2So4 Storage TankStarted by Guest_TeeEng_* , 08 Apr 2024 |
