Hysys Report In To Ms Excel Format
#1 dhns
dhns
  • 65 posts
Posted 22 July 2009 - 02:45 AM
Dear sirs,
Anybody could you please Explain about generating heat and mass table from
HYSYS Output result in to Ms Excel Format.
Please tell me the procedure,
thanks in advance,
Kind regards,
#2 AlertO
AlertO
  • 194 posts
Posted 22 July 2009 - 08:28 PM
you have an exel file generated by HYSYS, right? (it is created for special version of HYSYS)
Follow below procedure:
1. You open a HYSYS file with completed run.
2. Open that exel file.
3. Select the HYSYS file from the list.
4. Creat the data list that you want to get.
5. Select the streams that you want to extract data.
6. Now you can automatically extract all data.
7. Copy the data to your format that you want.
Hope, it's useful
  • guestGuests
  • 0 posts
Posted 23 July 2009 - 02:23 AM
Hysys has facilities for generating of H&MB, the facilities is Workbook dump,sometime this facility should be install separatly, but if workbook dump already install, it just click on this dump workbook.
#4 Padmakar Katre
Padmakar Katre
  • 992 posts
Posted 30 July 2009 - 10:26 AM
Dear,
There are two Excel-VBA worksheets I got from Aspen-Tech called Wrokbook Dump and HSR (Hysys Stream Reporter). Quite useful. You can download it from their support website. www.support.aspentech.com
