Hello.
I am trying to calculate how much the temperature of a fluid (styrene) would rise if it sits full in an unisulated 10in sched 40 pipe for up to 10 days during the summer. The reason we do not want to insulate the pipe is the risk of corrosion under insulation due to the pipe being in a flood plane. This pipe has to go under railways so we cannot raise it up too high (rail lines also get flooded). We are assuming it is 100F outside during the day and 80F at night. I'm not sure how to account for the solar radiation heating up the pipe, I've seen references to use 170 F but don't understand how this would be calculated. The pipe would be painted white.
Data:
Outside temp day: To(d) = 100 F
Outside temp night: To(n) = 80 F
Fluid temp: Ti = 75 F
Inside Pipe diam: di = 0.835 ft
Inside radius: ri = 0.4175 ft
Outside Pipe diam: do = 0.8958 ft
Ouside radius: ro = 0.4479 ft
Cross sect area: A = 0.5475 ft
Fluid: Styrene
density: p = 56.559 lb/ft^3
Specific heat: cp = 0.4132 BTU/lb-F
Thermal Conductivity
CS pipe: k(pipe) = 26 BTU/ft-h-F
Styrene: k(styrene) = 0.09245 BTU/ft-h-F
Air: k(air) = 0.0156 BTU/ft-h-F
The equation I was trying to use was to calculate the energy going through the pipe, but I don't think this is correct.
Using a length: L = 1 ft
q = k(pipe)*AL*(Ti-To(d))/(ro-ri) = -58046 BTU/hr !!this value seems way to high!!
AL = 2*3.14*L*rL = 2.716289
RL = (ro-ri)/LN(ro-ri) = 0.43253
Any suggestions/corrections/ideas would be greatly appreciated,
Thanks.
Heat Transfer From Ambient Air Into Pipe
Started by alan1979, Aug 06 2009 07:59 AM
No replies to this topic
Posted 06 August 2009 - 07:59 AM
![]() Pipe Segment In Hysys Not SolvingStarted by Guest_Frya_R_* , 20 Jul 2025 |
![]() Pipe Fluid Temperature Increase Due To Solar LoadingStarted by Guest_HeemeshJ126_* , 06 Apr 2016 |
![]() Guidance On Sizing Jacketed Pipe For Glycerine CoolingStarted by Guest_Kentucky08_* , 28 Jun 2025 |
