Hi all~
I just started using Aspen Plus, i m wondering what is the equivalent of the Hysys Recycle module in Aspen Plus?
Thank you in advance!
Andina
Recycle Module In Aspen Plus
Started by , Sep 01 2009 08:08 PM
Posted 01 September 2009 - 08:08 PM
Posted 02 September 2009 - 08:57 PM
Andina,
As far as I know, ASPEN does not require a recycle block. ASPEN analyzes your flowsheet to determine the streams that should be teared and proceeds accordingly. If you wish to specify the tear streams by yourself, that is also possible (this would be like an equivalent of recycle lock of HYSYS)
Hope this helps,
Abhishek
Hope this helps,
Abhishek
Posted 03 September 2009 - 03:35 AM
Thanks Abhi,
I agree with you.
I agree with you.
Posted 08 September 2009 - 07:06 PM
thank you very much!
Centrifugal Compressor Performance Curves In Aspen HysesStarted by Guest_Rafcio_* , 14 Mar 2024 |
Centrifugal Compressor RecycleStarted by Guest_Lyne_* , 19 Aug 2025 |
Sigma Profile For Cosmo-Sac In Aspen PlusStarted by Guest_R.t_* , 14 Aug 2025 |
How To Model The Bitumen In Aspen Plus?Started by Guest_engrbab01_* , 28 Jul 2025 |
