Gas Flow
Posted 02 September 2009 - 04:26 AM
flow rate
velocity
density
downstream pressure
pipe diameter/length
of a gas flowing in a pipe how do I calculate pressure drop ?
Posted 02 September 2009 - 07:17 AM
Let you try Perry's chemical handbook or Crane technical paper N 410 .
Hope it helps
Posted 02 September 2009 - 07:24 AM
I know
flow rate
velocity
density
downstream pressure
First, i assume you are a student. If so, you should have posted this question in the student forum.
I think you should go back to basics and, in particular, Darcy equation.
Posted 02 September 2009 - 07:33 AM
Originally developed in 1942, the latest edition of Crane TP-410 serves as an indispensable technical resource for specifying engineers, designers and engineering students.
TP-410 is published by Crane Valve Group (CVG), one of the world's leading suppliers of valve products and services.
It can be purchased for a nominal fee at http://www.flowoffluids.com/tp410.htm
It has many example problems with their solution.
Posted 03 September 2009 - 03:56 AM
Let me expand on the problem... I want to do a pigging run on a gas line about 5 mile long 6 inch diamter.
I know pipe spec, velocity, flowrate and initial pressure at launcher. I want to calculate what the receiver pressure will be ( gas will be flowed to flare )
Posted 03 September 2009 - 03:32 PM
Posted 04 September 2009 - 03:19 AM
Posted 04 September 2009 - 04:47 AM
Mohtogh is on the right track. You need to go back to basics and follow latexman advice.
Posted 04 September 2009 - 09:20 AM
It would be beneficial if you gave some data. What is the flow rate, velocity, density, downstream pressure, and pipe diameter/length that you know? Do you know what the gas is, molecular weight, compressibility (z) and Cp/Cv? This data will help us give better answers/advice.
Btw, what have you done/found in your effort to solve/research this problem?
#10
Posted 09 September 2009 - 09:17 AM
v = 2.5m/sec
q = 160 m3/hour
d = 0.5908
upstrm press = 40 barg
d = 150 mm
l = 7400 metres
mw = unknown
z = unknown
cp = unknown
gas is natural gas 95% methane
#11
Posted 09 September 2009 - 09:26 AM
dear all,
it would be of great help(and the only one needed)if one of those who have the crane paper
#410 to offer it for download. some of us can't afford $45 plus p&p.
best regds
iceman
I think you will find that is copyright infringement and therefore illegal.
And if you are an industry professional and can't afford $45 you need to reconsider going back to macdonalds as you aint making much in this game.
#12
Posted 09 September 2009 - 09:02 PM
#13
Posted 10 September 2009 - 03:40 AM
d = 0.5908 (gas density)
sorry typo
#14
Posted 10 September 2009 - 01:31 PM
For a good article that discusses the calculation of pressure drops for NG download http://www.psig.org/...s/2000/0112.pdf
Edited by katmar, 11 September 2009 - 11:09 AM.
#15
Posted 10 September 2009 - 07:48 PM
Genrally what you need to do before every pig run is to calculated the pigging rates, with inputs from the gas sales nominations (or the planned rate of flow).Calculate the expected ∆P across the line (Using gas-flow DP equations), compare it with the actual ∆P (Your current reading from the well to your terminal or reciever) and approximate the quantum of liquid expected from the pipeline (by 2 phase flow calculation/precedence).Then plan the pigging accordingly (Liquid draining rates...monitoring etc). Individual flow rates from wells were determined/altered accordingly.
The cricial thing here is to know how much liquid can be expected....if you have sand or muck in the line its another issue.
#16
Posted 11 September 2009 - 12:00 AM
#17
Posted 11 September 2009 - 08:17 AM
There is no liquid it is dry gas.
There is no sales gas compressor. The gas flows direct from wellhead to flare (7.4 Km away). We bypass the plant during pigging
What I am looking to calculate is the pressure I should have at the receiever so I can adjust my contriol valve to that pressure.
#18
Posted 11 September 2009 - 09:09 AM
katmar - that link didn't work for me this morning. It may be a temporary problem though.
#19
Posted 11 September 2009 - 11:15 AM
latexman - thanks for the feedback. I had put the file type as .pd instead of .pdf. I have edited it now and it should work.katmar - that link didn't work for me this morning. It may be a temporary problem though.
#20
Posted 15 September 2009 - 12:13 AM
No liquids expected during pigging? OK...
Can you elaborate on the purpose of this proposed pig run. I had assumed it was a cleaning run with the intent of removing liquid hold up and debris.
Is it a pipeline inspection with an intelligent pig?? In any case, if you can send us a brief sketch/schematic incl properties, conditions, linelength etc , maybe we can help you better.
Thx
#21
Posted 13 October 2009 - 10:08 AM
It is indeed an intelligent pigging run (mag flux) temp/press of gas is 25 C and 60 bargHello Viking,
Thx
basically a straight run of 150 mm pipe 7400 metres long.pig goes in one end and is driven by gas pressure
and other end is open to flare
can I put this problem a different way ??
Imagine I have a pipe an inch diameter and 100 feet long
I put a table tennis ball (negligible mass) just slightly under an inch diameter in the pipe and apply 10 psi pressure
How can I calculate the time it will take to reach the other end ?
#22
Posted 14 October 2009 - 12:54 AM
Hello Viking,
Thx
Pls see attached file.
Request someone to check the basis and calculation.
VikingUK please give me your feedback.
Posted 14 October 2009 - 03:42 AM
Hello Viking,
Thx
7.44 seconds for a mag flux pig to travel 7400 metres ???? I think there is something seriously wrong with that spreadsheet...!!!!
#24
Posted 14 October 2009 - 04:05 AM
Hello Viking,
Thx
Yeah thats what i thought initially, but i verified the calculation using Campbell solved example (In the theory section).Come to think of it, if you had 60 barg pressure at inlet....you completly open the inlet valve, and no pressure at the downsteam of the 6" line you actually would have some serious velocity.
That is why you would have to crack open the inlet valve to the pig reciever pressurize it to maybe 0.5 barg and then the pig would probabely take 10-15 minutes @ an acceptable velocity of 10 m/s to travel the 7.4 km distance.
If you suddenly open the well at 60 barg after loading the pig,i think the pig wont be a pig anymore..it would be "Superpig", travelling faster than a bullet, shattering the sound barrier.
PLEASE CONFIRM YOUR DOWNSTREAM PRESSURE..as you know, flow and velocity depend almost entirely on the pressure differential.
Wait for someone to give 2nd opinion.
#25
Posted 14 October 2009 - 07:18 AM
Hello Viking,
Thx
I think even though the downstream is open to flare there would be some back prressure as the gas would have to pass through a knock out drum and then reduce to the flare pipe (50mm diameter)plus a pressure regulation valve.
I think the overall dp may be quite low (10bar) so assume a downstream pressure of 40 barg.
The flowrate I am seeing at these pressures is about 180 m3/hour which calculates to a velocity of about 1.5-2.5 m/sec in a 150 mm dia pipe
Flow Through A Perforated PlateStarted by Guest_Ahmadhamzahperta_* , 13 Feb 2026 |
Gas-Liquid Pipe Flow Friction Loss CorrectionStarted by Guest_Huba_* , 18 Dec 2025 |
Software For Calculating Flow Through A PipeStarted by Guest_Deep24_* , 07 May 2018 |
Flow & Pressure Regulation For Compressible FluidsStarted by Guest_Abdessamed1961_* , 14 Dec 2025 |
Calculating Gas Flow Rate Without CvStarted by Guest_worrier_* , 25 Nov 2025 |
