Humidifier
Started by HKk, Sep 03 2009 01:46 AM
Posted 03 September 2009 - 01:46 AM
I am trying to figure out a design for a humidifier / direct contact cooler using gas liquid contact over a packed bed / tray column.The gas to the inlet is bone dry .So i am trying to utilise the latent heat of vaporisation for getting the cold water at bottom .
Can any body suggest me the method for the same & if it is better to use packed or tray column
regards
regards
Posted 11 October 2009 - 11:52 AM
regards
I would reckon it depend on your cooling requirement. It may be just a water direct injection to the gas pipeline, water spray in the gas vessel, or packed column as you suggested. The outcome of the selection should be cost justifiable.
HumidifierStarted by Guest_HKk_* , 04 Sep 2009 |
