Hysys 3.2 Vs Chemcad Vs Simsci Pro Ii
Posted 03 September 2009 - 10:29 AM
I found out 3 most common software’s.: HYSYS 3.2 vs CHEMCAD vs SimSci PRO II.
I found on the net the following training material available:
HYSYS 3.2 : a lot of manuals and examples.
CHEMCAD: few manuals and examples.
SimSci PRO II: 1 manual and no examples.
I would like to know under my situation (1 month and gas processing) what would be the easier/quicker to learn, use, simulate.....
Do you have some experience on the software’s mentioned? Any suggestion?
Thiago Coelho de Souza
Email me
Posted 10 September 2009 - 09:09 PM
I need to learn how to use simulation software within 1 month (full time) to do my final college project about gas processing, specifically a Dew Point Plant - DDP. The project subject is to simulate a chiller to refill the propane refrigeration system. I'll have to simulate a Stabilization Tower with a Reboiler, a Compressor (already in process), an extra Chiller to recuperate propane and a Biphasic Separator. I just want to do some few simple analyses like: basically mass balance. Possibly energy balance and economics as secondary objectives.
Email me
FYI, for simsci pro II actually there are some examples given in the program installation,,
by default you can find it under the directory C:\SIMSCI\Proii80\User\Applib,,
the examples are quite good for learning material,,
and you can also read the manuals under the directory : C:\SIMSCI\Proii80\Manual
but IMHO hysys is more user friendly and more easier to operate than pro II, (i have never use chemcad, so i dont know the comparison to chemcad)
CMIIW...
Posted 15 September 2009 - 08:50 AM
I will suggest you to use Hysys. As it takes normally less time to understand at least I found it user-friendly. As I worked on all these three simulators. Hysys will be good choice to start your Dew Point Depression Project. While doing simulations if you find any problem or need any help please let us know. All the best.
Posted 12 March 2010 - 07:56 PM
I would definitly go either with Aspen Plus or Hysys since they are top Notch. Chemcad is good as well but it has no distinct advantage over Hysys and Aspen.I need to learn how to use simulation software within 1 month (full time) to do my final college project about gas processing, specifically a Dew Point Plant - DDP. The project subject is to simulate a chiller to refill the propane refrigeration system. I'll have to simulate a Stabilization Tower with a Reboiler, a Compressor (already in process), an extra Chiller to recuperate propane and a Biphasic Separator. I just want to do some few simple analyses like: basically mass balance. Possibly energy balance and economics as secondary objectives.
Email me
Posted 13 March 2010 - 12:12 PM
Edited by wojtar, 13 March 2010 - 12:16 PM.
