in our new plant ( start up of new plant) procedures indicated that to produce MPS( 4.6 barg and T=161 oC) from HPS( 40barg and T=390 oC), HPS pressure after passing a Control valve droped to 4.6bar and to decrease the temperature we must inject Condensate( 14bar and 100 oC) .
maximum steam flowrate in high usage is 130 ton/hr and to decrease temperature of it we must use maximum 12 ton/hr condensate.
but todays that we began to start up this section of our unit, injecting of 12 ton/hr of condenstae (FT is callibrated and also we checked flowrate with time needed to rise the level in a barrel ) can't drop the temperature of 40ton/hr of steam and we can only decrease temperature to 256 oC.
we Checked the injection nuzzles and there is not any problem.
can you advice me?/
Edited by adeliry, 08 September 2009 - 07:07 AM.
