As you know,in the cases that back pressure of a PSV is well below critical flow pressure (Pcf) and discharge pipe terminated to atmosphere (or even into flare header with very large size) ther are two locations where pressure discontinuity (in the form of expanding jet/shock wave,...) might be occured:
-Between outlet plane of the nozzle of the PSV and inlet flange of discharge line
-Discharge pipe exit to atmosphere (or into large size flare header)
During relief, pressure difference between Pcf and superimposed back pressure included two above mentioned pressure discontinuities and pressure drop due to discharge pipe friction.
The question is: regardless of the pressure drop due to friction (could be calculated by specified relief load and pipe size,....) can we realize how much of total pressure discontinuity consumed in each of two above locations?
Any fast input highly appreciated.
Edited by fallah, 19 September 2009 - 06:37 AM.
