Hi dear,
This is regarding the relieving rate calculation for tube rupture scinario.
Process description: In kattle type reboiling condenser hydrogen along with C1-C6 (80% h2 and 20% hydrocarbon vol basis) flowing throgh the tube side and refrigarant throgh the shell side.
PSV is located at the shell side.
Design data:
Shell side design pressure: 13 barg ( refrigarant side)
tube side design pressure : 30 barg ( H2 and c1 to c6)
PSV set pressure is 12.5 barg.
How to calculate the relieving flow rate throgh the tube in case of tube rupture.
( Note: Tube side fluid is two phase where as tube bundle is submurge in the refrigarant in the shell side)
Thanks in advance
Arvind
Psv For Tube Rupture Case
Started by arvind, Sep 23 2009 05:37 AM
Posted 23 September 2009 - 05:37 AM
Posted 27 September 2010 - 04:28 PM
Arvind,
Follow API 521. Take 1 tube rupture( broken into two piece) as a basis for calculating flow for PSV sizing.
Best regards,
Satyajit
Best regards,
Satyajit
Posted 06 October 2010 - 08:36 PM
Arvind,
Normally , a complete tube rupture is assumed occurring at the tubesheet, such that on one side you have tubeside fluid flowing through the tubesheet (assumed an orifice) and on the other side , tubeside fluid flowing through the remaining part of the tube.
You have to calculate the flow thro the tubesheet side (orifice) and flow thro the tubesheet + tube side.You have to also consider whether flow thro the tube is choked or not.Being a 2 phase flow,"omega" method has to be used to calculate flows from both sides.
Once you have calculated flow from both sides , you add them and it becomes your relief load.You will have to know physical properties at the Relief pressure.
Once you have the relief load, the PSV needs to be sized.Again, use "omega" method (Appendix D, API 520)to calculate required relief area.
I have a technical paper in my office for this calculation. I will be able to upload it tomorrow.
Posted 07 October 2010 - 06:30 PM
Arvind,
attached is the paper I used to calculate tube rupture relief load.
![]() Rotated Triangular Tube Layout Vs Triangular Tube LayoutStarted by Guest_Heat Transfer Novice_* , 28 Sep 2024 |
![]() Supercritical Fluid Flowrate - He Tube RuptureStarted by Guest_flarewolf_* , 07 Apr 2025 |
![]() Tube Rupture ReliefStarted by Guest_felderosfelder101021_* , 16 Jan 2025 |
Fire Relief Case - Relieving TemperatureStarted by Guest_alexzo1990_* , 06 Nov 2024 |
Maximum Mass Flow In A Shell & Tube Heat ExchangerStarted by Guest_DonStalke_* , 22 Sep 2024 |
