hello
i want to know the variation in the performance of cooling tower if we change other parameters like Wet bulb temp, hot water temp, air flow rate, water flow rate etc.
for example if an existing cooling tower has the range of 45 degC-35 degC. if i increse the air flow rate then what will be the effect on the performance of the cooling tower.if we get more cold water then how much cold water will be?
the above question was just an exapmle.what i thik that this type of general question are very important for better understanding......
so plz help me.....
Cooling Tower
Started by chandresh, Sep 24 2009 11:47 PM
Posted 24 September 2009 - 11:47 PM
Posted 25 September 2009 - 12:19 AM
Dear ,
To support you query , do some google work . Plenty of information available on the net like : cooling tower fundamentals, cooling tower design ,..
Hope it helps
Hope it helps
Posted 25 September 2009 - 01:12 AM
In the software section of this site there is a little DOS program that does exactly what you want. Unfortunately, being a DOS program makes it unfriendly by modern standards but it is well written and has helped me out of a few holes. It makes you appreciate modern Windows programs!
![]() What Kind Of Cooling System Should I Use To Cool Down A Jacketed MixinStarted by Guest_HollyBoni_* , 31 Jan 2025 |
Ll Extraction TowerStarted by Guest_dpunnn_* , 22 Nov 2024 |
Flash Tower With Tray In Deoiling Of Wax?Started by Guest_AnbIran_* , 01 Jul 2024 |
