Could any one tell me why changing the size or number of tube pass thru the shell not change the result.
Is the hysys could not design the perfect number and size of the tubes????
Thank you very much
Edited by namir, 25 September 2009 - 11:27 AM.
Posted 25 September 2009 - 09:26 AM
Posted 25 September 2009 - 05:01 PM
Posted 26 September 2009 - 09:52 AM
Dear hysys group
Thank you very much
Posted 27 September 2009 - 03:16 PM
Posted 28 September 2009 - 12:31 AM
This could be a number of things. First of all, have you set the exchanger calculation mode to "Rating"? If it's set to "Design" the data on the configuration is ignored. Also, be aware that Hysys is not an exchanger design/rating program, so you do need to validate your results using HTFS or HTRI.
Posted 28 September 2009 - 08:56 AM
Posted 13 October 2009 - 10:22 PM
Go to Design Tab, Parameters page. Then use the Heat Exchanger Model dropdown box and select Steady State Rating.
Hysys-exchanger.PNG 18.56KB 44 downloads
