Pump Suction Pipeline Design Pressure
#1 Beergson
Beergson
  • 50 posts
Posted 06 October 2009 - 05:41 AM
Hi all
I work based at UOP Process Basis Design Package.
I wonder why UOP set up for pump suction pipelines (to gate valve before the strainer) design pressure (material class) the same as for discharge pipelines?
Do you have any ideas?
#2 gvdlans
gvdlans
  • 619 posts
Posted 06 October 2009 - 07:11 AM
Hi all
Please provide a sketch with a typical hook-up. Then we know what we are talking about...
#3 shan
shan
  • 692 posts
Posted 06 October 2009 - 01:07 PM
Hi all
Because it is parallel n+1 pump arrangement, the standby pump suction line may be pressurelized by the operating pump discharge.
#4 fallah
  • 5,019 posts
Posted 06 October 2009 - 01:16 PM
Hi all
It isn't a strange situation at all.
Potential of surge occuring in discharge line of a pump may lead to suction line subjected to surge pressure and therefore would be designated with design pressure same as that of discharge line.
#5 Sridhar P
Sridhar P
  • 44 posts
Posted 06 October 2009 - 11:05 PM
Dear fallan and Shan,
Can we generalise that for all pumps working on standy by arrangment, suction line design pressure, from sution isolation valve, to be same as the discharge pressure whether positive displacement pumps or centrifugal pumps.
Hope NRV provided on discharge line will not gurantee no dischare leakage to suction side.
#6 djack77494
djack77494
  • 1,282 posts
Posted 13 October 2009 - 01:39 PM
Sridhar,
You are right to say that a NRV (check valve) will not ensure that reverse flow will not occur. So given the situation with multiple parallel pumps, one or more being employed as spares, there is the possibility that a spare pump will have a closed suction valve and an open (or leaky) discharge valve. In that situation, the discharge pressure of the operating pumps is fully realized back through the spare pump(s) as far upstream as the (closed) suction valve. Totally sensible.
