Dear all,
I am working the LPG caustic wash revamp. The existing caustic wash drum is designed for 5,100 bpd LPG. The outlet will be sent to LPG Merox column. Caustic concentration is about 20 w%.
Now, the new conditions are: LPG feed is increased to 10,000 bpd, and keep caustic concentration to 20 w%.
My questions are:
1. what should I do to know the existing caustic wash drum is OK or not for the new capacity?
2. the same question for LPG Merox column
Thanks for your help!
Lpg Caustic Wash System
Started by dave2001, Oct 14 2009 10:41 AM
Posted 14 October 2009 - 10:41 AM
Posted 12 September 2010 - 12:30 PM
Answer to your each questions are as below:
Ans.: With your existing caustic wash drum you will face problem of high carry over of caustic with LPG & another problem of frequent change out requirement of spent caustic. It is advisable to go for review of caustic wash drum sizing with respect to your new revised feed flow.
Ans.: I hope you are going to maintain C/H ratio of 4 in your merox column. According to that you will required to find your new caustic flow. This flow rate should be permissible for that column efficient operation.
Psv For Refrigeration SystemStarted by Guest_runnerup_* , 30 Jun 2025 |
![]() Psvs Relieving To Closed Drain SystemStarted by Guest__1angelia23_* , 12 Jan 2025 |
![]() Strategy For Adequacy Check Of Multiple Bdvs In A SystemStarted by Guest_nabeelsp1036_* , 22 Jan 2025 |
![]() What Kind Of Cooling System Should I Use To Cool Down A Jacketed MixinStarted by Guest_HollyBoni_* , 31 Jan 2025 |
Using Different Types Of Prvs To Protect The Same SystemStarted by Guest_FarrahC_* , 09 Dec 2024 |
