Hai friends,
I am an engineering graduate in the field of chemical engineering. I want to become a process engineer. Guide me please. I have completed my diploma in 1993 and degree in 2008. I want to learn some chemical engineering software, pls help me.
Thanks & Regards,
Subramanian.G.K
Process Engineering
Started by Subramanian.G.K, Oct 16 2009 06:47 AM
Posted 16 October 2009 - 06:47 AM
Posted 05 November 2009 - 02:20 AM
Hi Subramaniam.G.K.
i suggest you to do research for some engineering companies. you can learn and work at the same time. it's better to understand and to apply your understanding in a real world. Good Luck!
Posted 12 November 2009 - 09:05 AM
We migh be able to provide you with a better quality response if you indicated your location and ability to relocate (if needed). Also, I noticed a 15 year gap between degrees, so I assume you may have some relevant experience. Knowing that may help.
Chemical Engineering ResourcesStarted by Guest_Pilesar_* , 24 Apr 2025 |
Going Through The Writing Process.Started by Guest_Haywardvek_* , 05 Jan 2025 |
Typical Process Of Platformate Splitter ?Started by Guest_AnbIran_* , 30 Dec 2024 |
