What Is "steam Blowdown"
Posted 19 October 2009 - 11:52 PM
Anyone can help clarify this one?
Thank you.
Posted 20 October 2009 - 07:09 AM
There are two kinds of “steam blowdown”.I see the phrase "steam blowdown" in some reading. After asking some friends, I received different answers. Some one said that it's the steam to clean up pipeline, equipment; while other said it is for removing contaminants from the steam.
Thank you.
1. When the plant is started up, steam is flowed through some operation units for cleaning up pipeline and equipment.
2. During boiler operation, water (condensate) is extracted from bottom of boiler to get ride of impurities accumulated in the boiler feed water.
Therefore, both your friend are right. The question is what your situation
Posted 20 October 2009 - 09:41 AM
Posted 20 October 2009 - 09:44 AM
Thank you.
vne,
The strictest sense of the term 'Steam Blowdown' is reserved for blowdown from the steam drum of a steam boiler. For cleaning piping/equipment with steam the term 'Steam Out' or 'Steam Flushing' is more commonly employed.
'Steam Blowdown' from boiler drum may be intermittent or continuous depending on the type of boiler whereas 'Steam Out' or 'Steam Flushing' is generally only applicable during commisioning, start-up & shut-down of equipment/piping and hence is totally intermittent in nature.
Hope this helps.
Posted 20 October 2009 - 09:47 PM
Posted 18 November 2009 - 08:58 AM
Thanks for you all, guys. Your answers brighten me up.
Steam blowdown come from the downcomers of the boiler (drum boiler), when the steam condenses it blows down and returns to the bled steam then to the superheaters of the boiler. On the 'once through boilers' the steam blowdown occurs when the steam from the turbine comes back as cold reheat to the boiler reheaters.
We then have the steam blowthrough, that is when we clean the boiler after commissioning the boiler (also called steam flushing) to remove the contaminants of the boiler.
Seeking Feedback On My Process Flow Diagram. Biogas Steam Reforming ToStarted by Guest_Jacobaum_* , 27 Oct 2025 |
Converting Superheated Steam To Saturated SteamStarted by Guest_addiesalsabil_* , 10 Sep 2023 |
Steam Flow And Heating Time In Batch ReactorStarted by Guest_seagal6_* , 16 Jul 2025 |
Steam On Shell Side Of A Vertical HexStarted by Guest_Lyne_* , 09 Jul 2025 |
Steam Carrying Liquid From The Sour Water Stripping TowerStarted by Guest_kaidlut_* , 12 Sep 2024 |
