Visbreaking Operation
Posted 23 October 2009 - 09:52 PM
I'm chemical engineer working in a petroleum refinery. We have a visbreaking(Thermal cracking) unit in our refinery. For a constant Furnace outlet temperature, we were trying to study the conversion(Gas + Naphtha) for various Vacuum residue feed (On processing different crudes in Crude distillation). We find that the ratio of feed viscosity to Vistar (Visbreaker bottoms) viscosity varies significantly.
We would like to know, what type of Vacuum residue feed is desirable for Visbreaker unit, to attain good conversion and higher ratio of viscosity between feed and bottoms?
Also, Does the visbreaker conversion will influence the viscosity ratio of feed and bottom?
Posted 18 November 2009 - 07:01 PM
Operation Of Heat Exchanger Above The Overall Heat Transfer CoefficienStarted by Guest_Papps_* , 13 Jan 2024 |
Variable Speed Pumps Operation.Started by Guest_panoska_* , 11 Oct 2022 |
Gas Turbine Simulation, Part-Load OperationStarted by Guest_twana_* , 21 Jul 2022 |
Tankage OperationStarted by Guest_Vegeta_* , 15 Jul 2022 |
Teg Dehydration Unit Change OperationStarted by Guest_AriefRahmanHakim_* , 13 Dec 2021 |
