Dear friends
In the Hysys oil manager, Assay data definition; we can define the Bulk density and density curve data if they are available.
Bulk density is defined as Standard density and therefore its condition is defined.
But if anyone wants to define density curve; it is not clear that this is density (Actual) or Standard density. If you change the unit of measure of all densities to API, the unit of this filed will change to API not API60.
I'd searched whole Hysys manual completely, but i can't find anymore information.
Can anyone know what is the real condition of density curve (Actual condition or Standard condition) in HYSYS?
Hysys Oil Manager
Started by extradoctor, Nov 02 2009 02:23 AM
