Simulation Of Liquid Liquid Extraction Column
Started by shrish, Nov 04 2009 08:13 PM
Posted 04 November 2009 - 08:13 PM
I was looking to simulate a liquid-liquid extraction column in Petro sim.
The two streams entering are:-
1).hydrocarbons+methanol(T=38C P=16kg/cm2_g Flow=35 m3/hr)
2).water(T=33C P=17kg/cm2_g Flow=2.7 m3/hr)
column overhead pressure is 10 kg/cm2_g and temp=44C
With these specs the column has failed to converge. (Errors:- Zero Matrix error. No soln possible with the current specs).
It would be of great help if someone could help me converge the column.
Posted 05 November 2009 - 08:46 AM
We use Aspen software. I would be happy to try your case if you forward more details.
Posted 05 November 2009 - 08:56 PM
Do you mean Aspen HYSYS.
Posted 06 November 2009 - 10:30 AM
No Aspen Plus.
Posted 10 November 2009 - 10:03 AM
I'd recommend you send in your issue to KBC's support helpdesk. software@kbcat.com.
Dynamic Simulation - SeparatorsStarted by Guest_tomr91_* , 10 Mar 2025 |
