I'm working with a single-pass shell and tube heat exchanger (108 tubes, 14.1 sq. ft heat transfer area). I've been tasked with experimentally calculating heat losses from the exchanger to the surroundings and then comparing the experimental loss with the predicted amount of heat loss based on the size of the exchanger, temperature of the exchanger surface, and temperature of surroudings.
I ran hot water through the tubes and cold water through the shell.
My method for experimentally calculating the heat lost to the surroundings is to find the difference between the rate of heat transfer on the shell and tube sides. In mathematical terms:
qtube - qshell = q lost to surroundings
qtube = (mass flow rate of tube water)*(Cp water)*(Tentering tube - Texiting tube)
qshell = (mass flow rate of shell water)*(Cp water)*(Tentering shell - Texiting shell)
When I do this calculation for the data I collected, I find that qtube = -26,054 Watts and qshell = 24,223 Watts. That gives a difference of 1,831 Watts. As I understand it, qtube is the heat lost from the hot tube side. Since the shell side only has 24,000 Watts, I'm assuming the rest of the heat was lost to the surroundings. Is that assumption correct, or could there be 1800 Watts accumulated somewhere in the heat exchanger?
To calculate the expected heat lost to the surroundings I used the following equation:
q = (Natural convection individual heat transfer coefficient, hL)(Surface Area of Exchanger)(Tsurroundings - Texchanger surface)
For natural convection in air at room temperature, the individual heat transfer coefficient varies from 1-100 W/m2K, so at the very most, my expected heat loss to the surrounding should be:
(100 W/m^2K)(.2 m^2)(4 K) = 80 Watts
I feel more confident in this theoretical answer than the one I got from my experimental data. Does anyone see an error in my reasoning?
Thanks in advance!
Edited by Kristen, 12 November 2009 - 06:33 PM.
