Blowdown System
Posted 14 November 2009 - 06:41 AM
I know that I’ve raised many questions here but your help would be much appreciated.
Posted 14 November 2009 - 12:55 PM
Now comes the confusion part for me. Why is there an expansion piece downstream of the isolation valve; to further drop the pressure (by increasing the volume with larger diameter pipe) so that the flare system is not pressurized? If so why is the spec break at the inlet of the expansion piece? Also I’ve noticed t hat in some system there isn’t an expansion piece. Why is this? And is there a rule of thumb that if the pressure is dropped by so much then an expansion piece is required.
The expansion piece would be located just downstream of the RO not isolation valve.The main concern in this situation is gas/vapor velocity (mach number) which would be greatly increased after RO due to expantion if expansion piece not being considered.
It is obvious that by considering larger pipe diameter after RO,not only pressure drop doesn't increase but also decreases due to higher pressure recovery.
Spec break normally would be considered at isolation valve located after RO for maintenance purpose.
Hope above help you out.
Posted 15 November 2009 - 08:48 AM
Although fallah has guided you fairly well.
I add my little explanation in very simple words;as linked to the possible point pressure/ temperature conditions of discharged (i.e. de-pressurizing stream.)
Most usually any system being safegurded is physically pressurized to MAWP condition just prior to 'physical blow down' or 'pressure relieving' and
localized sudden change of pressure to a much lower value may enhance its volume tremendously(subject to the characterstics of stream in question)
Now in order to protect against this increase of volume impacting the pipelines/ structures mechanically;it becomes imperative to have a properly designed expansion piece in-place accordingly ;where such tremendous volume increase is not foreseeable such expansion loops are not mandated.
Hope this guides somewhat on the conceptuality.
Posted 19 November 2009 - 06:04 AM
Junior1
![]() Psvs Relieving To Closed Drain SystemStarted by Guest__1angelia23_* , 12 Jan 2025 |
![]() Strategy For Adequacy Check Of Multiple Bdvs In A SystemStarted by Guest_nabeelsp1036_* , 22 Jan 2025 |
![]() What Kind Of Cooling System Should I Use To Cool Down A Jacketed MixinStarted by Guest_HollyBoni_* , 31 Jan 2025 |
Using Different Types Of Prvs To Protect The Same SystemStarted by Guest_FarrahC_* , 09 Dec 2024 |
