Does anyone know if there is a API standard for the maximum allowable leak rate (in grams/min or litres/min) for downhole safety valves (sssv) and other xmas tree valves ? I have seen 425 litres/min quoted but this seems high.
Leak Rates
Started by VikingUK, Nov 19 2009 05:41 AM
Posted 19 November 2009 - 05:41 AM
Posted 19 November 2009 - 05:59 AM
VikingUK,
The figure mentioned by you doesn't seem off the mark. Get hold of API RP 14C & take a look at Table D-2 of Appendix D of the standard. All 14 series API practices are for offshore (more stringent) but can be safely used for onshore operations.
![]() Nitrogen Leak Test On PipeStarted by Guest_mesbah_* , 24 Oct 2024 |
Ethylene Tanks Cctv For Leak DetectionStarted by Guest_DarthJamming_* , 30 May 2024 |
P&id Marking Up For The Leak TestStarted by Guest_JKM_* , 04 Jan 2023 |
Pro Ii - Adjusting Std Flow RatesStarted by Guest_lsoaresfernandes_* , 26 Oct 2021 |
Fuel Gas Piping Leak TestStarted by Guest_CSNK_* , 23 Aug 2021 |
