Hysys<->Matlb With Hysyslib(Olaf Toolbox)
#1 rgmmelo
rgmmelo
  • 4 posts
Posted 26 November 2009 - 06:22 PM
Hello, I try to use Hysyslib to export and import variables during dynamic simulation on hysys to matlab. I Can read variables from hysys, but when a I try to change a value in the cell on hysys from matlab, if the hysys run the value is passed with another unit, if stopped the correct value is passed. For exemple
passing(Hysys running) T=450 F the value in hysys change to 752, as 450 was in ºC and not in ºF.
Passing(Hysys running) F=1000 kg-mol/hr, they change to 3.600*10^6 in hysys, that is 1000(Kgmol/hr)*3600 seconds/hr.
I using Hysys 3.2 and Matlab 7.8.0. Any idea to solution this?
Edited by rgmmelo, 26 November 2009 - 06:37 PM.
#2 PSDC_YU
PSDC_YU
  • 17 posts
Posted 02 May 2010 - 04:21 AM
Hi
I dont much about hysys to matlab optimization but u can use the same objective function in excel connected through Visal basic
hope it is use ful to u
regards
khan
#3 joerd
joerd
  • 371 posts
Posted 03 May 2010 - 07:42 AM
I don't know how Hysyslib was implemented, and I don't quite see the difference in your examples, but Hysys' internal units are degrees C, and kgmol/s. It looks like your transfer function directly passes the value, without explicitly specifying the units of measurement. You should contact the programmer of Hysyslib and discuss it with him/her.
The correct syntax in Visual Basic would be ProcessStream.Setvalue(450, "F")
#4 Amiemashad
Amiemashad
  • 11 posts
Posted 18 March 2011 - 02:24 PM
I thinks you can help me and I would be very grateful if you guide me.
I want to connect my HYSYS to Matlab, actually I want to get a set of data in hysys automatically by matlab. I wonder do you know what should I do?
I wonder is Hysyslib suitable for my goal?
Thanks in advance
