Incinerator Control Temperature
Posted 15 December 2009 - 06:44 AM
is controlled at 600 deg.C. Is it wise to reduce upto 550 degC for
optimize fuel consumption. Other than ground level SO2 content , what is other effects.
I have seen in the literature that 1000 Deg F ( 538 degC)is sufficient for good
combustion of sulfur tail gas and a good dispersion of SO2 in ground level.
I would like to know what others are maintaing sulfur recovery plan incinerator temperature.
Regards.
Guest_saeid_*
Posted 15 December 2009 - 10:30 PM
hi aanitaIn a sulfur recovery plant(CBA Process), currently incinerator temperature
Regards.
I tested it.at higher load , you can see smoke at top of stack.
Posted 16 December 2009 - 01:59 PM
If smoke is black, insufficient air is supplied. Which one
is your case?
For my concern is to reduce temperature without any effects of
other parameters.
Thanks for your time.
Posted 22 December 2009 - 03:20 AM
Regards.
Hi Aanita,
I have seen SRU incinerators running at 550 deg cel and that will not be a problem at all.
Posted 22 December 2009 - 10:58 PM
can you give me some more details: is it a large SRU, what is the process( CBA or 3/4 stage Claus, stack details).
Thank you very much.
Posted 24 December 2009 - 03:48 AM
Koli
It's large SRU ( 675 TPD ) and CBA process.
Posted 24 December 2009 - 11:55 PM
Is it's normal operating temperature (55o Deg C)or ocasionally
kept lower value. It looks same for my case:capacitywise and also it is CBA process.
For my case we operate 600 Deg C, however we are trying to maintain less than
current operating (600 Deg C)temperature. I am affraid, it will increase ground level SO2 concentration.
Regards.
Posted 08 February 2011 - 10:56 AM
![]() Pipe Fluid Temperature Increase Due To Solar LoadingStarted by Guest_HeemeshJ126_* , 06 Apr 2016 |
Parallel Control Valves Downstream Relief ScenarioStarted by Guest_pklavinsJ_* , 18 Jun 2025 |
