Liquid And Steam Control Valve
Started by paidis, Jan 06 2010 07:08 AM
Posted 06 January 2010 - 07:08 AM
we have one flow control valve ( 8 inch) that designed for liquid flow of 286 ton/hr hydrocarbone ( most component are paraxylene, MX, OX,Ethylbenzene ) and now we want to use it for steam line ( 8 inch.) with flow of 0~30 ton/hr .
i know design of liquid and steam valve is difference , but i want to know if we can use this valve or not
thanks .
thanks .
Posted 07 January 2010 - 01:12 AM
The fact that the valve was previously used for a liquid hydrocarbon is irrelevant. In order to know whether you can use the valve for your steam application you need to know the pressure and temperature rating of the valve, its material of construction and Cv.
Posted 07 January 2010 - 03:57 AM
Look at the thread: http://www.cheresour...izing-in-hysys/ and download reference materials.
Posted 07 January 2010 - 06:01 AM
And about the delta P across the valve?
