Modulating Type Pilot Relief Valve
Posted 12 February 2010 - 07:33 AM
As per API521 table-12, teh lateral (outlet line) sizing for modulating type pilot relief valve should be done based on required flow rate only and there is no mention of RV inlet line sizing for modulating pilot type relief valve. As per my understanding, the construction and functionailty of RV will not allow the RV to reach the rated capacity. Howeever, I dint find any convincing document which says that inlet line sizing should be also done based on required flow rate only.
appreciate some expert comments on this issue.
aju
Posted 12 February 2010 - 12:58 PM
Hi all,
aju
Be sure,inlet line sizing calculation for modulating type of pilot operated valve should be done based on required flowrate.This can be seen in design manuals of some famous companies such as FLUOR Co.
Posted 14 February 2010 - 01:27 PM
I worled with Bechtel in past and I know this guidelines are normally available as a corporate guideline in good companies but in other companies when we have to demonstrate this we cant rely on other company guieline.
If you know any other source then plwase let me know. I am checking with vendor in parallel.
Rgds
Aju
Posted 14 February 2010 - 01:46 PM
ยง4.2.3 of API RP 520, Sizing, Selection, and Installation of Pressure-relieving Devices in Refineries Part II - Installation?Thanks fallah,
Rgds
Aju
Posted 15 February 2010 - 05:45 AM
Thanks fallah,
Rgds
Aju
In my opinion,specified part (in red closed loop) of attached page indicates validity of using required relief load as a basis for inlet line sizing of modulating type PSV.
Please inform me about the result from checking with vendor.
Edited by fallah, 15 February 2010 - 05:50 AM.
Parallel Control Valves Downstream Relief ScenarioStarted by Guest_pklavinsJ_* , 18 Jun 2025 |
Selection Type Of Heater For Refrigerated PropaneStarted by Guest_livetolove003_* , 07 May 2025 |
