Not too surprising that they all stayed in the vapor. You need to calculate or look up bubble and dew point curves for this. At 500 K, the vapor pressure of pure water is 25-30 bar: at 3 bar it would all be a vapor even if it was pure water. In order to separate them by some kind of vapor-liquid separation operation, you're going to have to locate the two phase region so you can operate at those conditions.
hope that helps.
I tried to change stream conditions at 298 K and 1 bar, but nothing changes.
I tried to draw on Pro/II the T-xy diagram at 1 bar: at 400 K it indicates a mole fraction of water (dew point) of 250000!!
If I try to draw a P-xy diagram at 500 K, it appears this warning: "Bubble point flash did not solve. Final temperature(k)= 500, pressure(kpa)= 578490, lfrac= 1, function= 0, tolerance= 1e-5. (a dew or bubble flash in the supercritical region is an arbitrary phase change that is expected to fail.)."
