Casing Velocity Verses Shaft Vibrations
Posted 17 February 2010 - 06:57 AM
Posted 17 February 2010 - 08:01 AM
Ash:
What you call "casing velocity" is assumed by me to mean machine volumetric flow rate. High speed rotating machines, such as turbo-expanders and centrifugal compressors don't necessarily rely on exhibiting vibrations due only to volumetric flow rates - certainly not to the point that they will reach an alarm point or shutdown level. Vibrations in centrifugal compressors (at least in the well-designed and proven models) are, in my experience, primarily due to mechanical design and mechanical limitations. These can be bearing design and loads as well as impeller type and designs. Varying machine speeds also have a marked effect. The type of capacity control(s) that you apply also can have an effect. If you are employing recycle gas as a capacity control versus speed control, there could be a difference. You just can't make a general statement without furnishing detailed background information as to type of machine, make, model, capacity ranges, types of controls and vibration ranges.
Bearing life, design, and condition can have a marked effect on any vibration characteristics.
Posted 19 February 2010 - 07:45 AM
In general,
vibration velocity can be calculated as V = 2*pi*f*d mm/s peak-to-peak, where f=frequency in Hz & d=displacement in mm peak-topeak &
vibration acceleration can be calculated as A = 2*pi*f*V mm/s^2 peak-to-peak.
And your question is, when V changes, why do A or d not change.
Valid one.
The answer to the question is:
Casing vibrations are measured using accelerometers (siesmic probes) & the results are differentiated by FFT to velocity or displacement rms or peak-to-peak. Depending on the frequency range of the probes that feed data to the FFT & the capability of the FFT to accurately interpret the data, the result varies.
Further, the actual vibration originates at the rotor & measured at the bearings. This gets "conducted" to the casing & other parts of the compressor.
For shaft displacement measurement, two proximity probes are arranged orthogonally & the signals from the two are crunched by the Bently or other system to arrive at the position of the shaft or its diaplacement. This is far more accurate than the results provided by the accelerometers mounted on the casing, as the calculations are pretty straight forward.
You dont seem to be too familiar with the fundamentals of vibration theory. It is extremely important to use the right terms & units in vibration measurement. You may try these two extremely good books
Fundamentals of Rotating Machinery Diagnostics by Bently &
Machinery Malfunction Diagnosis by Eisenmann
Edited by akslzf, 19 February 2010 - 08:23 AM.
Posted 20 February 2010 - 02:55 PM
Thanks akslzf for the interesting information. Mechanalysis (the term used in late 1970s) has been a useful diagnostic tool for preventive plant maintenance. Educative seminars took place as that time, but these were for mechanical engineers. I worked then in Fertlizers (Operations), and we notified maintenance immediately on observing vibrations of rotating equipment, though this was not planned maintenance. Only steam turbogenerators had systematic follow up of vibrations due to potential scales on turbine blades....the actual vibration originates at the rotor & measured at the bearings. This gets "conducted" to the casing & other parts of the compressor.
Once vibration data (schlumberger contact sensor used) of a grinding mill was sent to supplier, just after reception test. This could be due to resonance, since rotational speed of the mill was changed during the tests. In all other cases vibrations were signs of equipment malfunction, or loss of balance (more rarely). The latter could happen on induced air fans (e.g. of cooling towers), apparently when balancing rods on blades got shifted. But it was also due to scales or corrosion, e.g. on fans.
It is assumed that any diagnostic tool has some probability of failure /misinterpretation, though this seems rather low for mentioned method.
Increased flow rate within the specified limits for the equipment did not cause vibrations (it may be the case for increase beyond limits).
Hope above information is useful to those not being familiar with mechanalysis, considered (at least locally) as field of mechanical engineer.
Edited by kkala, 20 February 2010 - 03:03 PM.
Posted 29 March 2010 - 07:16 PM
![]() Fired Heaters/ Burners/ Flue VelocityStarted by Guest_Lyne_* , 15 Mar 2024 |
![]() Recommended Fluid VelocityStarted by Guest_crn_* , 16 Apr 2025 |
C Factor For Erosional Velocity For Multi-Phase Flow (Nat Gas/ ProduceStarted by Guest_Sam11_* , 10 Sep 2024 |
