I am wondering for how to calculate/ decide optimum column operating pressure if I knows (limit) the cooling water outlet temperature to 42°C. and the available low pressure steam is at 4 bar gauge. for depropaniser.
Thanks and regards,
Arvind
Posted 19 February 2010 - 02:21 AM
Posted 19 February 2010 - 03:16 PM
Posted 20 February 2010 - 02:38 AM
Thanks and regards,
Arvind
Edited by fallah, 20 February 2010 - 02:40 AM.
Posted 21 February 2010 - 02:23 AM
when deciding the operating pressure at column top, the following procedure should be followed:
1) Determines the maximum cooling water or ambient air temperature that is typically expected on the hottest summer day in the locale where the plant has to be built.
2) Calculates the condenser outlet (reflux drum temperature) that results from the above water or air temperature. How?, taking an approach about 10C
3) Assuming that the condensed liquid is at its bubble point (as normally is), then you must calculate the reflux drum pressure (saturation pressure @ temperature calculated in point 2).
4) Adding 5 or 10 psi to the pressure calculated in 3, allowing some pressure drop in the overhead system (condenser and associated piping) you calculate the tower top pressure.
Beware about the CW return temperature. If hot (above 45-50C) the carbonates starts to precipitate increasing the fouling in the exchanger tubes and pipes.
Best regards,
GERARDO VILLAMIZAR PLATA
Posted 22 February 2010 - 05:41 AM
Best regards,
Posted 01 March 2010 - 09:19 AM
