Vertical Tank Tilted
Posted 05 March 2010 - 01:08 AM
I would appreciate direction to calculate the volume of liquid inside a "vertical" tank slightly tilted due to soil sinking .( Known are the geometry of the tank: L, D ; the slope ; the reference point (nozzle) to measure the height of liquid).
Posted 05 March 2010 - 03:41 AM
Posted 05 March 2010 - 04:15 AM
http://www.lmnoeng.c...InclinedCyl.htm
Posted 06 March 2010 - 12:44 AM
Posted 08 March 2010 - 09:30 AM
Attached "tilted.pdf" may help, giving a simplified formula for the volumes above ground and below ground. It is noted that e.g. Lcosθ=Η for above ground cylinder (θ=angle of the axis to perpendicular).I would appreciate direction to calculate the volume of liquid inside a "vertical" tank slightly tilted due to soil sinking .( Known are the geometry of the tank: L, D ; the slope ; the reference point (nozzle) to measure the height of liquid).
In case that tank bottom is seriously distorted, another method has to be applied for the volume below ground (or any definite horizontal level), as the calibration proposed by Katmar.
Can you inform order of magnitude for angle θ or slope? Probably θ is very close to zero, otherwise tank would have to be dismantled.
Edited by kkala, 08 March 2010 - 09:32 AM.
Posted 08 March 2010 - 06:50 PM
Thanks Kostas ,Attached "tilted.pdf" may help, giving a simplified formula for the volumes above ground and below ground. It is noted that e.g. Lcosθ=Η for above ground cylinder (θ=angle of the axis to perpendicular).
For your question : the slope : 7 centimeters for 7 meters height
Posted 09 March 2010 - 11:24 AM
Thus tanθ=0.01, θ=0.573 degrees, H=l*cosθ=0.99995l. Even if l=30 m, H=29.9985 m; so difference between l and H can be hardly distinguished; neglecting such slope may affect volumetry precision quite marginally.the slope : 7 centimeters for 7 meters height
Distortions may play a greater role.
Edited by kkala, 09 March 2010 - 11:36 AM.
Posted 09 March 2010 - 06:42 PM
Kostas ,
The quantity of material is strictly monitored by "authorities"!
Thanks again .
