Hi all,
I'm trying to use Aspen to solve a problem for class. Basically I have a mixed stream of cyclohexanol, phenol, and cyclohexanone that I would like to separate. I'm trying to use DSTWU to do this, but every time I do this I get some sort of error. I've received errors that say that the bubblepoint calculation timed out after 16 iterations, that the minimum reflux ratio calculated with the underwood equation is negative and is being set to 0.1, not converging within 25 iterations, etc. I've played around with the values a lot to try to get it to work. I'm aware that my feed stream components form azeotropes, but shouldn't I be able to get it to run even if they form azeotropes? Or do these impact the calculations that Aspen does with the DSTWU, making them impossible.
To condense all this down to a more reasonable series of questions:
1.) Does the presence of an azeotrope in a stream prevent me from using DSTWU?
2.) How do I specify DSTWU correctly. Are there any rules of thumb about picking reflux ratios, recovery rates, condenser/reboiler pressures, number of theoretical plates?
Thanks!
Dstwu Aspen Issues
Started by mobezo2, Mar 08 2010 05:22 PM
No replies to this topic
Posted 08 March 2010 - 05:22 PM
![]() ![]() Centrifugal Compressor Performance Curves In Aspen HysesStarted by Guest_Rafcio_* , 14 Mar 2024 |
Sigma Profile For Cosmo-Sac In Aspen PlusStarted by Guest_R.t_* , 14 Aug 2025 |
How To Model The Bitumen In Aspen Plus?Started by Guest_engrbab01_* , 28 Jul 2025 |
