The thickness of pressure vessel is calculated based on internal pressure Pi by the equation t = PiD/2fj, but in case of full vacuum t becomes zero, then how one can find the value of t?
This statement again demonstrates the importance of clearly indicating
WHAT pressure you are talking about. Using the Imperial pounds per square inch (psi) units, you may be talking about gauge pressure (i.e. relative to atmospheric), expressed as psig, differential pressure (i.e. difference between any two pressures), expressed as psid, or absolute pressure as psia. Substitute the pressure units of your choice (e.g. barg, bard, bara), but please
ALWAYS keep the suffix.
Mr. Dhirajkumar equation is correct for dealing with the calculated metal wall thickness to withstand
INTERNAL pressure. Vacuum inside a vessel can be thought of as
EXTERNAL pressure, and Mr. Dhirajkumar's equation is
NOT applicable for that situation.
The whole idea of specifying that a vessel should be designed for "Full Vacuum" is a well known and (in my opinion) sensible concept. It is often specified for vessels that might undergo steamout, as Art discussed. Though no one thinks that an absolute vacuum is attained, the vessel walls may need to withstand differential pressures that could approach 14.6 - 14.7 psid (External). It is not easy to specify a limit (or to say
HOW close to full vacuum might be possible.) Furthermore, it is not important since even if through excruciatingly difficult calculations you could show (for example) that the minimum internal pressure would
ONLY be -14.4 psig. So what. Engineering is ALL about being practical, which in this situation means skipping the calculation and rounding up (down) to full vacuum, almost certainly adding FULLY zero to the vessel's cost.
Doug
