Posted 31 January 2011 - 09:02 AM
Mentor,
Equation for flocculator power input is as follows:
P = G2*mu*V
where:
P = Theoretical Power input to water, W
G = velocity gradient, s-1
V = Flocculator Volume, m3
mu = Dynamic Viscosity of water, N.s / m2 (1 cP = 0.001 N.s / m2)
Optimum flocculation occurs when G is in the range 10-100 inverse seconds (Page 25-65, Perry's Handbook, 7th Ed.)
The overall volume of the flocculator tank (rectangular) would be L X W X D
You can adjust G in the above equation for a given rectangular tank volume to arrive at the desired power input. Alternatively for a given G and P value you can determine the flocculator tank volume. As you might have noted in the above equation volume is an input and not the dimensions. The dimensions can be adjusted in practical terms to arrive at the given or calculated flocculator volume.
