I would appreciate if someone can help me in recommending the fouling factor to use for clean steam and condensate in a shell and tube heat exchanger. Steam goes to a steam turbine and condensate comes from the steam turbine as well
Thanks in advance
Jose Mendiguren
Fouling Factor For Steam/condensate
Started by jmendiguren, May 25 2011 04:01 AM
Posted 25 May 2011 - 04:01 AM
Posted 25 May 2011 - 05:53 AM
Jose,
Refer Appendix VII in the document found in the link below:
http://www.chemstati...icles/shell.pdf
This should provide you the answer.
Steam Carrying Liquid From The Sour Water Stripping TowerStarted by Guest_kaidlut_* , 12 Sep 2024 |
