I am looking at a system with natural gas coming into an offshore platform at high pressure >1000 psig. There are no condensates / liquid hydrocarbons. The produced water is to be sent to a closed drain and I expect it to have small amounts of dissolved gas. How is this produced water to be treated before being discharged offboard ( typical oil skimmers etc might not be required as there is no oil coming into the platform). How is the gas disposed ?
Can any one show a typical sketch for this system (ie produced water treatment when there is no oil but only dissolved gases).
Posted 03 October 2011 - 12:25 AM
Posted 03 October 2011 - 10:22 AM
Dissolved hydrocarbon gases or worse dissolved H2S in produced water needs to be handled very carefully and you require seal-pots or U-shaped siphons to prevent their migration and accumulation on the offshore decks.
I had prepared a standard on "Drain Systems" for an offshore O&G company in the middle-east which also had a lot of illustrations related to off-shore platform drain systems. I am attaching a sketch related to seal-pot and a U-shaped siphon.
Hope this helps.
Ankur
Hope this helps.
Ankur
Edited by ankur2061, 03 October 2011 - 10:23 AM.
Drain And Vent Destination LpgStarted by Guest_Priolo_* , 14 Feb 2026 |
Psvs Relieving To Closed Drain SystemStarted by Guest__1angelia23_* , 12 Jan 2025 |
Pressure Drop Due To Entry Loss At Liquid And Gases Inside The ColumnStarted by Guest_SANDEEPCH_* , 24 Oct 2024 |
Closed Loop Pump Suction Line Sizing CriteriaStarted by Guest_Afshin445_* , 30 Aug 2024 |
