The picture attached demonstrated a batch reactor containing a fixed volume of Reverse Osmosis Retentate (highly concentrated waste seawater).
I have an input stream at the bottom linked to a pressurised canister of carbon dioxide gas and a flow meter of some sort.
The CO2 gas is going to be fed into the batch reactor vessel which will be continuously stirred with the use of an agitator and hopefully micro bubbles of gas will pass up through the liquid and react with the RO retentate - obviously I want the bubbles to be as small as possible so that more gas can react with the solution. Any excess gas should exit the top of the tank and possibly be incorporated back into the cycle if applicable.
The aim of experiment is to try and precipitate MgCO3 through this reaction at the exit stream. the liquid effluent and solid carbonates shall be produced.
Mg^2+(aq) + CO3^2-(aq) = MgCO_3 solids
So the main question is what parameters should I examine - I have already thought of a few:
- The volume of the tank should be kept constant, maybe design the experiment with 1 litre of RO retentate present in the tank initially?
- How can i get the CO2 to form tiny bubbles, through the use of a nozzle perhaps?
- I will need to measure the initial concentration and examine any changes that happens in the reaction.
- Type of flow meter to be attached, and how will I even get the CO2 gas stream to attached to it and then to the bottom of the vessel?
- I know what seawater usually has a pH of around 8.5/8.6 - alkaline. By adding CO2 gas, it will form carbonic acid which in turn will lower the pH, is this worth analysing?
- Gas will need to exit from the top so that there will not be an increase in pressure
- What experimental apparatus would be reasonable to use to precipitate MgCO3 from the product stream?
- The carbon capturing technique is carbon sequestration, correct?
- Henry's law appears to be an important parameter to examine especially with CO2(g) -> CO2(aq). meaning that: Yco2 x P = Xco2 x H. whereby, y is the Y is the mole fraction in the vapour phase, X is the mole fraction in the liquid phase, P is absolute pressure and H is henrys constant, which for CO2 at 25degrees is 1,670 H/bar ( taken from Introduction to Chemical Engineering Thermodynamics by Smith, Van Ness and Abbott. - How would i determine X and Y for this reaction?
- Looking at Henrys law could further suggest looking into dissociation of CO2,equations of state, fugacity, equilibrium relationships etc - is this all relevant?
I thank you all in advance and look forward to hearing from you!
Andrew
Edited by peaston, 16 December 2011 - 12:07 PM.
