Flow Rate Of Flue Gas
Posted 20 December 2011 - 05:46 AM
CO2=4.68%
please do the hurry........
aditya
Posted 20 December 2011 - 07:06 AM
Please help me in finding flow rate of flue gas whose flue gas composition is O2=13.9%,CO=0.002% &
CO2=4.68%
aditya
From which stack? Which fuel combustion?...?....?
Edited by fallah, 20 December 2011 - 07:34 AM.
Posted 20 December 2011 - 07:18 AM
Posted 20 December 2011 - 01:30 PM
Flue gas flowrate = Air flowrate + Fuel flowrate
Edited by sheiko, 20 December 2011 - 01:32 PM.
Posted 21 December 2011 - 05:03 AM
Aditya9,
sheiko,
At least you could say; Flue gas flowrate={Excess air+Gaseous mixture (resulting from combustion)+not combusted fuel (gaseous)} flowrate
Fallah
Edited by fallah, 21 December 2011 - 05:08 AM.
Posted 21 December 2011 - 05:59 AM
sheiko,
Fallah
Fallah, I believe my MASS balance is correct in first approximation, except that I could have added atomising steam (if Fuel is liquid).
Moreover I disagree with yours as "not combusted" fuel cannot remain after a complete combustion, revealed by the presence of excess air (as you have written).
Regards.
Posted 21 December 2011 - 06:37 AM
Fallah,I believe my MASS balance is correct in first approximation, except that I could have added atomising steam (if Fuel is liquid). Moreover I disagree with yours as "not combusted" fuel cannot remain after a complete combustion, revealed by the presence of excess air (as you have written). Regards.
sheiko,
Thoretically/ideally and provided that complete atomizing would be done for liquid (in real world doesn't occur) and for 100% complete combustion your mass balance could be right.
Again, complete combustion without excess air is an ideal phenomena and in real world we may have unburned fuel in its reaction with stochiometric value of the air due to some reasons such as the temperature be lower than needed, presence of impurities in fuel, uncomplete atomizing,.....
Fallah
Edited by fallah, 21 December 2011 - 06:39 AM.
Posted 21 December 2011 - 11:13 AM
fallah is right in the way to estimate flue gas composition, which is useful in calculating volumetric flow rate at certain flue gas temperature. The value O2=13.9% (v/v? on dry basis?) indicates excess air, so complete combustion. CO=0.002% is a small quantity (25 mg/Nm3) that could be created even at excess air. Typical CO content in flue gases is 100 ppm = 0.01% v/v, and typical O2 content 2% - 6% v/v http://www.keison.co...isfluegas.shtml , so 13.9% looks high.
B. Suppose that fuel complete composition(%C, H, S, etc, w/w) is known, as well as its mass flow to burners:
1. If excess air is given, flue gas composition and molar flow rates* can be estimated
2. If flue gas (precise) full composition is given, excess air and molar flow rates* can be estimated.
In both above options unburnt fuel is assumed as 0, sustained by the excess air.
Examples can be found searching the forum, e.g. http://www.cheresour...ue-gas-quantity,
*from molar flow rate of each component, total mass flow rate of flue gas and total volumetric flow rate at a specific temperature can be estimated.
Edited by kkala, 21 December 2011 - 12:18 PM.
Posted 21 December 2011 - 12:01 PM
Regarding the supposed excess oxygen content of 13.9%, it rather looks like the excess air content, which value is around 5 (= 100/21) times the % O2.
Edited by sheiko, 25 December 2011 - 05:30 PM.
#10
Posted 21 December 2011 - 09:47 PM
CO2=4.68%
aditya
Dear Aditya,
It couldn't be calculated, because the data only for mol/ volume fraction. there is no partial rate that must be identified.
Flow Through A Perforated PlateStarted by Guest_Ahmadhamzahperta_* , 13 Feb 2026 |
Gas-Liquid Pipe Flow Friction Loss CorrectionStarted by Guest_Huba_* , 18 Dec 2025 |
Software For Calculating Flow Through A PipeStarted by Guest_Deep24_* , 07 May 2018 |
Flow & Pressure Regulation For Compressible FluidsStarted by Guest_Abdessamed1961_* , 14 Dec 2025 |
Calculating Gas Flow Rate Without CvStarted by Guest_worrier_* , 25 Nov 2025 |
