Maximum Permissible Speed
7 replies to this topic
#1 ahmedensem
ahmedensem
  • 11 posts
Posted 02 February 2012 - 03:31 AM
hello everyone,
I'm traying to size my pipe transferring Fuel for a project in morocco.So to determine the diamter's pipe I need know the permissible speed of the Fuel in this pipe,which make necessary for me asking if there is a standard fixing this speed between two values?
any help will be very appreciate
  • 6,942 posts
Posted 02 February 2012 - 03:47 AM
let you use the search button , key words : pipe maximum velocity .
It should help
Edited by breizh, 02 February 2012 - 05:47 AM.
#3 Absolute Zero
Absolute Zero
  • 92 posts
Posted 02 February 2012 - 04:05 AM
As a rule of thumb process engineers consider the following maximum velocities:
For Liquid Line Max 15 ft/sec
For Gas Lines Max 60 ft/sec
#4 ahmedensem
ahmedensem
  • 11 posts
Posted 03 February 2012 - 03:50 AM
thinks friends,I got it
#5 Art Montemayor
Posted 03 February 2012 - 08:30 AM
I believe Zak is quoting wrong velocities. The nominal design velocities employed in process design of piping I have always worked with are:
For Liquid Lines: (Normal) 5 ft/sec; Max. = 10 ft/sec
For Gas Lines: (Max) 100 ft/sec
#6 kkala
kkala
  • Banned
  • PipPipPipPipPip
  • 1,939 posts
Posted 03 February 2012 - 02:06 PM
You can find line sizing criteria in http://www.cheresour...id-line-sizing/ '> http://www.cheresour...id-line-sizing/ , posts of 6 Oct 2011. Data seems to generally comply with post No 5, with more details reported.
#7 vikramltv
vikramltv
  • 52 posts
Posted 06 February 2012 - 01:46 AM
ZAK's sizing criteria is highly acceptable as it is based on API RP-14E.
We can alter the design criteria depending on which code or standared we are following.
#8 Absolute Zero
Absolute Zero
  • 92 posts
Posted 06 February 2012 - 08:04 AM
The Criteria I mentioned are based on "Recommended Practice for Design and Installation of Offshore Production Platform Piping Systems API RECOMMENDED PRACTICE 14E (RP 14E)"
